ROG Azoth switches are always red although they are advertised as having blue and brown options.
Maffey48
I have been trying to buy a ROG Azoth keyboard with Asus Blue switches yet every shop listed on the list of places to buy, such as Ebuyer, Amazon, Scan, CCL, etc in the United Kingdom, all have red switches.
Even Asus's product page, where you can buy products in the UK, doesn't have an option for the blue or brown switches that the keyboard is advertised to have.
Is it simply impossible to buy a keyboard that is advertised because all the shops insist on having red switches, even though blue and brown are far more popular?
Aureliannn_ASUS
Hi @Maffey48 ,
thank you for your inquiry.
The ROG Azoth keyboard is advertised to come with hot-swappable pre-lubed ROG NX mechanical switches.
These switches are customizable, allowing you to tailor your typing experience.
The available switch options include NX Blue, NX Red, and NX Brown.
Would you like to replace the switches at the moment?
You can refer to the FAQ below for replacement instructions.
[ROG Keyboard]ROG Azoth ASUS Gaming Keyboard Features Introduction | Official Support | ASUS Global
