10-26-2024 02:30 PM
I've had the mouse for a while and it worked fine on the Bluetooth, all of a sudden it disconnected randomly and wouldn't reconnect via Bluetooth
I tried using forget device and now I can't get it to appear in the searching for devices tab
And I've tried everything from restarting to updating to reinstalling
It works fine when I use the dongle
10-31-2024 07:37 PM
Hi @RealRyn ,
Thank you for contacting ASUS support.
We understand that you are experiencing issues with your Bluetooth connection. To troubleshoot this issue, we recommend that you try the following steps:
If the issue persists after trying these steps, we recommend sending your mouse to an authorized service center for further diagnosis and repair.
Official Support | ASUS Global
