Keyboard Z Flow Mode Error
SetiawanIND
Hi ,
I am using ROG Z Flow 13 I9 Gen 12 , i have problems with my keyboard when the keyboard sticking to monitor (standard mode) the keyboard is turn off (not work) but the position changed to floor mode the keyboard is normally.
This condition was happened after update windows.
I was do :
1. Try with safe mode
2. Recovery windows update
But the results still not work.
Falcon_ASUS
@SetiawanIND
Regarding your question, we recommend that you visit the following forum to get more assistance.
https://rog-forum.asus.com/t5/gaming-notebooks/bd-p/HSS_Notebooks
We apologize for any inconvenience this may cause.
Danishblunt
Hall of Fame I
Common issue, the cables within the keyboard rip over time. The Z13 is awful to begin with with horrid battery life and performance, the keyboard failing is only icing on the cake, also you cannot get a replacement keyboard either without ASUSs mercy.
Good luck.
