Rog strix G15 battery indicator issue.
- System:
- Battery or AC:
- Model:
- Frequency of occurrence:
- Reset OS:
- Screenshot or video:
Detailed description:The battery indicator turns to white even when the battery is not fully charged.
0
Comments
Hi there,
Please enter BIOS, and load default setting again.
Then disconnect all external device and adapter, long press the power button for 40 seconds to reboot the device.
Let me know if you still have the issue.
Hello, could you please tell me how to enter BIOS?
Please refer to below link
disable battery saver ,, normally to charge from 90 to 100% , it takes more time than charging time than from 0% to 60%
Where to load default settings? Please let me know.
@Blake_ASUS please give me detailed steps.
After you enter BIOS, there is a "Default(F9)" at the bottom bar, press it and will lead you to load default setting.
issues still not solved yet.
