Battery problem after .087 update
- Model Name:Asus zenfone max pro m1
- Firmware Version:.087
- Rooted or not:not
- Frequency of Occurrence: Everytime
- APP Name & APP Version (If your issue relates to the app): Battery
After the latest .087 update on my Asus zenfone max pro m1 battery draining too fast.Before this latest update overnight battery drains just 2-5% but after the latest update overnight battery drains 20-30%. And in this forum many Asus zenfone max pro m1 users have this problem after the .087 update . So don't tell asus “please change your battery from near the service center". It is a software bug so please fix it by the update. I calibrate my battery and the screenshot is there.
0
Comments
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
I think they will not fix bugs but can have more bugs in system update. 😅.
Asus team nothing think about their customers . They only know the selling market . After this I will not buy & will not suggest anyone for Asus mid-range smartphones. 😡😡
They are poor on software.
I realised “Asus smartphones yani bugs ka dukan".
Factory Reset is The Only Option during such draining battery after most of Updates.....remembered fixing it up that way but it could be just for me.
Asus Stock ROM is bullshit, Better Get used to custom roms already.
I reset my Asus zenfone max pro m1. But the battery problem not gone . It's a very annoying issue.
Did you tried checking in safe mode?
There is high night drain after .87 update 😡
Yeah, I am tried checking in safe mode. But nothing will not be happen.
Yes, after .087 update there is high battery draining
