Hi
tabaunnurhabibytThank you for your asking. Kindly try some stay-at-home troubleshooting tips below:
1. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps, aka the compatibility between specific 3rd party apps and the current firmware.
https://www.asus.com/support/FAQ/1005163/2. Also, please try "the Factory Reset"
Settings>System>Advanced>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
3. If the issue remains the same after performing the Factory Reset, please contact ASUS repair center in the country of your residence for further device checking:
https://www.asus.com/support/Service-Center-All-Countries/If it is impossible to access the service center during Covid-19 period, please try Call us:
https://www.asus.com/support/CallUs
