KENAPA BATERAI BOROS??
Model Name:ASUS ZENFONE MAX PRO M2
Firmware Version:9
Rooted or not:No
Frequency of Occurrence:?
APP Name & APP Version (If your issue relates to the app):-
Mau nanya min hp saya kan Asus Zenfone Max Pro M2,yang baterai nya 5000mah tapi kok boros bgt ya?
Christine_ASUS
Community Legend II
Hi andikakerenbanget
Thank you for your asking. Kindly try some stay-at-home troubleshooting tips below
1. Enter "Safe Mode" and leave a 100%-charged phone in sleep(idle) mode in a night, then provide me the screenshot of
①Setting>Battery
②Setting>Battery>3 dots on the top"Show app usage"
If the battery works well in "Safe Mode", please check on any disturbance from the installed 3rd party Apps.
2. If the "Fingerprint" is turn off, does the situation remain the same?
Settings>Security>Fingerprint
3. Does the issue appear right after any system/apps' download or update? What is your current firmware version
Settings>System>About Phone>Build Number
If you try to update to the latest version, does the issue still persist?
4. Also, please try "the Factory Reset"
Settings>System>Advanced>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
5. Is there any zone heating up while using/idling? How long has the battery been used?
For more information, please refer to the links below
https://www.asus.com/support/FAQ/1009546/
https://www.asus.com/support/FAQ/1009547/
