Android-Auto Wireless issue
Hi guys,
last Tuesday I have installed new head unit in my car ( JVC KW-V950BW ), when I bought this head unit it was advertised as a Android Auto wireless compatible ( and it is ).
so the Android Auto basically works with wire once I enter developer to activate wireless projection on the Android auto it's stopped working completely cause car tries to connect to it wirelessly and won't work with wire anymore,
and on wireless keep sending me error 4582 ( on head unit ).
Today I have tried doing it with another phone ( Galaxy S9 ), and it works ( same Android-Auto version and settings ).
so that's excludes head unit as the problem here.
Things I have tried to do on my phone:
Updating to latest Version
Downgrading to Android 9
getting into developer in Google services app
nothing works.
Comments
What does "error 4582" mean in the manual for the head unit?
You shouldn't need to enable Developer Mode to get Android Auto working as it is already built-in as part of Android.
It wouldn't even try to connect to it wirelessly without the developer option ( even on the second phone ).
My bad it's Error 4852 and the message is: "Unable to start Android Auto. Please check your phone"
The only suggestions I have is:
If the head unit is remembering the device, remove it first.
On your phone, clear cache and storage by going to:
Settings - Apps & Notifications - See all X apps - Press on the 3 dots top right corner - Show System - locate Android Auto - Storage & cache - Do clear storage and clear cache.
So I just tried what you suggested, I have initialized the head unit so it will delete all the data, and cleared the Storage and cache as you said, Still doesn't work.
I'm up for anything else you have in mind
thank you for trying.
Sorry, I don't have another suggestion to this. But I have been Googling around for this issue with the model number.
The only thing it comes up with is that Android Auto is out of date.
Can you check to see if you have up to date versions of Android Auto in your car head unit? ROG 2's was last updated on 18th June for mine. Probably worth checking the Samsung's Android Auto app is the same version as ROG 2 and if it is, ROG 2 could be the issue.
My car head unit is using the latest firmware.
And using same AA version on the galaxy phone
I managed to connect it to the head unit.
I'm pretty sure the issue is with the ROG 2.
is there a way to debug it/get logs to what's going wrong there?
Thanks for the response. Are the two Android Auto the same versions too? ROG 2 and the Samsung phone.
Yes, both phones are using Android Auto version 5.502264-release
@doondoon5 I can send you instructions via PM on how to log your device.
UP!
I'm still having the issue, please if anyone ever encountered similar issue please let me know how you solved it.
thank you.
@Gustav_ASUS sent you a PM with instructions on how to log the phone. Once you have log the phone, get in touch with the log.
I have sent them the Log, and waiting for their answer.
with that no one can promise they will solve it and there might be someone who encountered such issue before.
Ahhh Ok, have you tried messing around with the Bluetooth settings in the Developer Options?
There's AVRCP option that you can switch.
Only a suggestion while you wait for someone to respond back to you.
Thanks for another idea, just tried it and sadly still no difference
Thanks for trying - I guess I am out of suggestions to try.
