Android-Auto Wireless issue
doondoon5
Hi guys,
last Tuesday I have installed new head unit in my car ( JVC KW-V950BW ), when I bought this head unit it was advertised as a Android Auto wireless compatible ( and it is ).
so the Android Auto basically works with wire once I enter developer to activate wireless projection on the Android auto it's stopped working completely cause car tries to connect to it wirelessly and won't work with wire anymore,
and on wireless keep sending me error 4582 ( on head unit ).
Today I have tried doing it with another phone ( Galaxy S9 ), and it works ( same Android-Auto version and settings ).
so that's excludes head unit as the problem here.
Things I have tried to do on my phone:
Updating to latest Version
Downgrading to Android 9
getting into developer in Google services app
nothing works.
15 REPLIES 15
ronald1985
Community Legend I
doondoon5
https://zentalk.asus.com/en/discussion/comment/95637#Comment_95637
So I just tried what you suggested, I have initialized the head unit so it will delete all the data, and cleared the Storage and cache as you said, Still doesn't work.
I'm up for anything else you have in mind
thank you for trying.
Sorry, I don't have another suggestion to this. But I have been Googling around for this issue with the model number.
The only thing it comes up with is that Android Auto is out of date.
Can you check to see if you have up to date versions of Android Auto in your car head unit? ROG 2's was last updated on 18th June for mine. Probably worth checking the Samsung's Android Auto app is the same version as ROG 2 and if it is, ROG 2 could be the issue.
doondoon5
ronald1985
https://zentalk.asus.com/en/discussion/comment/95645#Comment_95645
My car head unit is using the latest firmware.
And using same AA version on the galaxy phone
I managed to connect it to the head unit.
I'm pretty sure the issue is with the ROG 2.
is there a way to debug it/get logs to what's going wrong there?
ronald1985
Community Legend I
doondoon5
https://zentalk.asus.com/en/discussion/comment/95807#Comment_95807
Thanks for the response. Are the two Android Auto the same versions too? ROG 2 and the Samsung phone.
doondoon5
ronald1985
https://zentalk.asus.com/en/discussion/comment/95814#Comment_95814
Yes, both phones are using Android Auto version 5.502264-release
Gustav_ASUS
Community Legend III
@doondoon5 I can send you instructions via PM on how to log your device.
