Updated my Zenfone Max Plus (M1) with BIOS from 7 to 8.1. Do I also need Kernel Source Code as well
mentorron
Is it necessary (or advisable) to install the latest Kernel Source Code (ASUS ZenFone Max Plus (M1) Kernel Source Code for WW SKU) after doing a manual update from Android 7 to 8.1 using ASUS ZenFone Max Plus (M1) Software Image Version: WW-15.02.1904.453 (Android O) For WW SKU only* ??? Please explain why I should or shouldn't. Thanks.
1 ACCEPTED SOLUTION
Accepted Solutions
Falcon_ASUS
@mentorron
The source code is provided in accordance with Google's requirements, mainly for reference by individuals interested in developing their own apps. If you want to manually update the system to Android O, please download the firmware update manually. For detailed steps, please refer to the following instructions.
[Phone] How to update firmware on my phone?
Falcon_ASUS
@mentorron
ZenBot
Community Manager
Community Manager
