Hi jimmychou,
Good day.
Do you mean the phone temperature not too high but the system pop on the temperature high message while charging?
Do you use the Asus original adapter and cable? Is your firmware version is on WW-15.0200.1812.503?
I would suggest you check this matter under safe mode. Or For exclude caused by software, please kindly try to backup phone files and factory reset. Sorry for any inconvenience.
