04-12-2020 12:40 AM
04-12-2020 02:29 AM
il SantoThat random vibration during a call happens to every Max Pro M2 users and it happens only when you are on a call talking through the earpiece speaker and it feels like its vibrating because our cheek is touching the screen. Right??On my Max Pro (M2) while I am calling the phone vibrates very annoyingly. I found that from calling screen, the phone often turns to battery option screen. Unwillingly I set some option with my face. If I press on/off button before closing the phone to my ear the problem reduces a lot: still vibrates, but doesn't switch to battery option screen. I have. 73 build.
Very annoying vibration issue
04-12-2020 07:36 AM
04-12-2020 07:51 AM
04-12-2020 10:55 PM
il SantoI also had this issue, when 'double tap to turn screen on' was enabled. Can you try switching that off and see if phone vibrates on call screen?On my Max Pro (M2) while I am calling the phone vibrates very annoyingly. I found that from calling screen, the phone often turns to battery option screen. Unwillingly I set some option with my face. If I press on/off button before closing the phone to my ear the problem reduces a lot: still vibrates, but doesn't switch to battery option screen. I have. 73 build.
