Very annoying vibration issue
il_Santo
On my Max Pro (M2) while I am calling the phone vibrates very annoyingly. I found that from calling screen, the phone often turns to battery option screen. Unwillingly I set some option with my face. If I press on/off button before closing the phone to my ear the problem reduces a lot: still vibrates, but doesn't switch to battery option screen. I have. 73 build.
22 REPLIES 22
il_Santo
With normal calls seems they have solved. With Whatsapp's voice calls the issue still remain but is far less annoying than before.
Sanju
https://zentalk.asus.com/en/discussion/comment/75736#Comment_75736
Have you tested it thoroughly? Because I disabled the double tap to wake thing to get rid of it. Will check then.. 👍🏻
Sanju, keep in mind than my firmware is .75 WW. I don't if the indian version is exactly the same.
BlueHunt
Zen Master I
il Santo
https://zentalk.asus.com/en/discussion/comment/75739#Comment_75739
Yeah, Indian users also received that ww sku .075 version. Thanks for reminding, I forgot to check that I didn't even enabled the gesture to check but took a lot of calls.. my bad. Will let you know later whether the same is fixed for me too or not. 👍🏻
il_Santo
One more thing I have discovered. After some use (days), the issue represents though in a light way. With. 075 firmware, restarting phone solves again for some days.
