System update
L_S
When I try to update its not working. When I try to download it said "Asus software update download in process from last night
What can I do in this case
20 REPLIES 20
L_S
My system is Asus X01DBA
L_S
Sanju
https://zentalk.asus.com/en/discussion/comment/75157#Comment_75157
I know your OS version as Android 9.. what I want to know is what is current Firmware version?
To check, go to Settings -> System -> About Phone -> scroll down to the bottom and check the Build Number starting with PKQ..
PKQ1.WW_Phone-16.2017.2002.073-20200219
BlueHunt
Zen Master I
L S
https://zentalk.asus.com/en/discussion/comment/75202#Comment_75202
Okay, now as you said that you are on .073 version, thats why your download was not happening. Because as per the screenshot you posted with your first post, we can see that FOTA Version is also showing up .073. Download was failing because you were already on .073 version.
Now follow the below mentioned steps carefully and do exactly :
Copy the following link and paste it to a new tab on your browser to download the .075 Firmware version which is the latest version for Max Pro M2.
https://dlcdnets.asus.com/pub/ASUS/ZenFone/ZB631KL/UL-ASUS_X01BD-WW-16.2017.2004.075-user.zip
Once download is complete, do not open the zip file. Just move it to the Root directory of your internal storage in the File Manager.
Once moving is done, restart your phone and upon restarting, an update notification would start showing up at the notification bar. Tap to install the .075 version.
Prabir_Metya
When the April security Patch Update is given to the device Asus Zen fone max M2 please tell me as soon as possible
L_S
Sanju
Thanks system updated
