Battery drainage
I charged my phone to 80% and then switched it off.
After a few hours , I switch ON my phone and battery is at 23%.
Why is this happening??
BlueHunt
Zen Master I
reddynikhil2000
Battery drainage
Your battery life is ended due to any hardware failure since you said you switched off your phone but it still drained out the battery to 23% from 80%.
You should visit the service center for a thorough check-up once the lockdown is lifted and service centers are operational.
victor010
Zen Master III
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue factory reset your phone after taking a full backup.
4. Last option would be to visit the service centre to have
a check once they open in your area. Locate here: https://www.asus.com/in/support/Service-Center/India
