Weird bootloop after OTA (21 April 2020)
Adu
Model Name: Zenfone Max Pro M1 (ZB601KL)
Firmware Version: 16.2017.2004.063
Rooted or not: Not
Frequency of Occurrence: First Time
APP Name & APP Version (If your issue relates to the app): N.A
My asus zenfone max pro m1 has not been booting since the april 21st update.
It boots completely, asks for pattern to decrypt storage and irrespective of whether or not i enter the pattern, it reboots. Looks like some system services are failing after boot and hence i need to wipe or clean flash the system partition.
Situation:
This is my dad's phone and it wasn't tampered with at all. Unfortunately boot loader is locked and usb debugging is off.
None of my 2 laptops detect it in fastboot or adb in windows and linux. I've installed proper drivers but it doesn't even show up in device manager as unknown or whatever.
It normally enters fastboot and recovery modes.
I did the root integrity check from recovery and it reported 92 files missing and 90 unknown files.
What i tried:
Reinstalling the same update through recovery (makes no difference)
Installing older updates ( recovery doesn't allow)
Factory reset through recovery (makes no difference)
flashing via fastboot (fastboot doesn't detect)
The only thing i did not try is qfil and I'm not doing that because a lot of people have reported losing their IMEI and other hardware information.
Also, I couldn't find a stock qfil firmware they were stock based made by other people.
Asus's update broke the phone. But I don't see a lot of people posting about it. I could use some help.
Thank you
victor010
Zen Master III
Hi, we suggest you to please visit the nearest ASUS service center for better assistance  once they are open in your area post lockdown. Locate here : https://www.asus.com/in/support/Service-Center/India
