12-25-2020 08:06 AM
Solved! Go to Solution.
12-25-2020 09:15 AM
vijimanisakthiTry SIMMI test and check if microphone & speaker are working well to entre simmi test follow this steps👇
- Model Name: ASUS_X00TD
- Not rooted
Speaker of my phone stopped working all of a sudden.
Was playing music, attended a call and then resumed music. But when I resume, speaker output was not clear.
A few days later there was no output from the speaker.
Microphone also did the same, while sending voice notes on whatsapp, there was no input recorded.
But had no issues with call (couldn't use loudspeaker option, but other futures worked good)
A few months after, while I am using gmeet or zoom, notification sounds started to come. But if I close zoom/gmeet then again there's no speaker output.
Speaker not working
12-25-2020 09:15 AM
- Not rooted
Speaker not working
12-26-2020 08:25 AM
12-28-2020 05:47 AM
BeckyEmiliaI have done a reset and it is working now.... THANKSOpen calculator press .12345+= and follow test option you want to
Thanks for this amazing tip!
