Serious Ram Management Problem. Please help If you have any solution
knightfdark
Model Name:Max Pro M1 3gb
Firmware Version:
Rooted or not:
Frequency of Occurrence:Frequently
Applications always restart every time I reopen any app most of times. I'm facing this problem in every version android 9 as well as android 10.Its so irritating I'm unable to do any multi tasking even on 2-3 apps are open
Please tell me any solution if you know.
mroceanisback
In developers options check this is enable or disable, if enabled, disable it and check if it work.
knightfdark
mroceanisback
it is disabled already
victor010
Zen Master III
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue factory reset your phone after taking a full backup.
