Hello i am quote Daihen Chu.
I disable it always so i don't turn it back on because it will make my phone get hot.
Hope this works for you.
"Hi guys,
• UPDATE:
After charging from 50% to 100% (takes about 1.5 hours) but the heating occurs again, the 4 cores of the CPU were loaded 100% statically again so I do disable and enable the service "Media Storage" as the old way so it is no more full loaded of 4 cores. I don't know whether the quick charge is conflicted with "Media Storage" service. Asus experts have to discover about this issues cause it is very annoy to users and If I do not disable and enable the "Media Storage" like that, the phone would be warm up and the battery would be drained out quickly (it will lost 1% every 10 mins. without using the phone).
• Temporary solution:
I have solved the problem about heating of the Max Pro M2 (3GB version) after upgrading to the Android P (Android 9)
The solution is we have to find the system app called "Media Storage" in the "App & notifications" tab and to Disable and Enable again so this task will reset the app and everything will be fine.
The reason is 4 of 8 cores of the CPU were loaded to full 100% so it caused the temp to be raised up always.
When I did the task as mentioned above so all was solved, the 4 cores will back to about 30 - 35% as my case and it will never reach 100% statically and the phone will be cool down.
I have compared with my old Pro Max M1, the cores of the CPU now were the same loading and the heating was gone.
I hope that this tips can help.
Best regards
Daihen Chu"
www.asus.com/zentalk/forum.php?mod=viewthread&tid=303679&extra=page%3D1%26filter%3Dlastpost%26orderb...
