Notification light & phone slowness
AJ1
Rising Star II
1. Why does the notifications light starts blinking continuously when there are NO Notifications, No battery saver? & when there are notifications coming Light does not blink at all.
2. Phone slowness started. After September 2020 there is no update for PRO M1 device. Phones performance is not good & taking quite bit time for other activities to do. Apps gets hanged, websites / Gmail load slowly.
3. Calls issue when call is picked no voice of other person can hear need to call again.
Version A9.
Update - .87
It is irritating to use such phone with nothing plan by the company further.
8 REPLIES 8
abhaykrishnan02
Zen Master I
Yachendra
https://zentalk.asus.com/en/discussion/comment/145863#Comment_145863
I know that. But @AJ1 said that it's blinking when battery saver is turned off.
That's reason I asked him for at what :battery: % light blinks.
Oh sorry ,by mistakely i tagged u🙏
AJ1
Rising Star II
Yachendra
Battery % is more than 50%. Even when battery is full or more than the desired battery level the light starts blinking unnecessarily.
abhaykrishnan02
Zen Master I
AJ1
https://zentalk.asus.com/en/discussion/comment/145868#Comment_145868
Follow this step
abhaykrishnan02
https://zentalk.asus.com/en/discussion/43082/notification-light-phone-slowness
Notification light will start blinking if your battery percentage is less than the schedule you have set to start battery saver
To stop this
Open setting - battery - battery saver-set a schedule - now decrease the battery % 🙂
, I'm sure your problem will be fixed
Yachendra
Rising Star II
AJ1
Once, you turnoff and turn on again and see "blink light".
Also, Check in safe mode. If light not blinks then it'll be due to 3rd party apps.
Is this issue occurred after installing any app? If yes, uninstall.
If you don't know exactly the app, you can reset the device.
