01-05-2023 04:47 AM
01-13-2023 01:21 AM
Hi, according to your question, may I ask whether your product model is ZB601KL?
For ZB601KL, the latest firmware version is Android 10 AOSP version WW-17.2017.2012.438
You can refer to the following link.
ZenFone Max Pro (ZB601KL) - Support (asus.com)
If there's any problem while using Android 10, please manually downgrade to WW-16.2017.2009.087 version.
yesterday
I'm using an Zenfone Max Pro M2 (Asus_X01BDA) model, would you also know if I can upgrade the Android OS from 9 to 10?
