[Bug 432] Slow wifi speeds on Max Pro M1
siddharthdas876
I am getting slow wifi speeds in latest Android beta 432 on asus zenfone max pro M1 as compared to pie.
Like I used to get 1.9-2 MBps and now getting 1.2-1.4 MBps on 432
10 REPLIES 10
Christine_ASUS
Community Legend II
Moved from harshithkumar40 /432 ASUS MAX PRO M1 [SIGNAL STRENGTH, WIFI SPEED, SOUND CLARITY/
I have recently updated from pie to A10 version 432 .
I have found these issues in A10 beta 4
1) Signal strength is weak as compared to Android 9
2) Wifi speed and low wifi signal (compared to Android 9)
3) Sound is improved but Missing sound quality both (speaker and earphone)
[CORRECT ME IF AM WRONG]
Hi harshithkumar40
Please avoid overlapping thread or message, which may disturb the mods and the users to solve the issue. Besides, I will test the function tomorrow.
Christine_ASUS
Community Legend II
Moved from rumputliar30 /Weak WIFI signal/
I have problem with WIFI. Signal very low.
Hi rumputliar30
Christine_ASUS
Community Legend II
Hi friends
Thank you all for your asking. I have forwarded the information of the Wi-Fi signal to the relevant department. We will keep you updated and your consideration will be very much appreciated.
Christine_ASUS
Community Legend II
Hi friends
After internal testing, we confirmed that the Wi-Fi signal in Android 10 beta V432 performs as well as which in Android 9. Thank you.
p.s. I have done cross testing with same device and WiFi router in different firmware versions.
