Max pro m1: Audio bugs android 10 beta,build 432
rumputliar30
Model Name:Max pro m1 (ZB602KL)
Firmware Version:432 global (WW)
Rooted or not:no
Frequency of Occurrence:-
APP Name & APP Version (If your issue relates to the app):-
Bug report:
If i listen music with my music player,and listen youtube web together,sound quality drop,no bass,very flat sound.
Sound volume from 70% to 100% not difference.
RAW image capture not work
Sound quality need more improvement and balancing and tuning.
4 REPLIES 4
kapooratish77
exact same issues
Christine_ASUS
Community Legend II
Hi friends
Some issues are already under discussion in other threads, please go to the link I mentioned to avoid overlapping information
1. What is your music player app? Do you encounter the same issue with other apps + youtube web? If you use youtube app, do you encounter the same situation?
2 & 4. Sound. Please refer to the link as below
https://zentalk.asus.com/en/discussion/comment/118333
3. RAW image capture. Please refer to the link as below
https://zentalk.asus.com/en/discussion/36420/
Christine_ASUS
Community Legend II
Besides, because the issues you reported are all related to AUDIO, please avoid overlapping thread or message, which may disturb the mods and the users to solve the issue...
ASUS_Bot
Rising Star II
