Asus zenfone max pro m1 Android 9 build 84
usakiyem
Rising Star I
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
Battery drain so fast please give me solution
34 REPLIES 34
usakiyem
Rising Star I
sayyedsharuk55
A10 Stock Latest .429
Charging speed must be 1800-2000mA in Ampere app.. otherwise change your charger..
pubg played in Smooth+Extreme FPS...
Build 429 ka battery backup tik hai
dibyarupprk2011
Rising Star II
sayyedsharuk55
Check that after getting calls if you receive the call notification lately by 3 to 4 Seconds
Sathesh
mysahil0369
I haven't updated to 084 yet !
Should I ? Or not ?
Not, strictly no
Sathesh
sahaa6919
To be honest with you , the phone's battery backup is pretty decent .. You just have to not use your phone unnecessarily and if you think that battery is draining fast , do calibration .. It really works .. And , if u use ur device recklessly , the phone's battery will surely damage and will result in weak battery .. Take care of your device .. I'm adjoining a screenshot .. See , 2hrs time is left even on heavy usage in 25% battery ..
Calibration is just waste of time, and don't call it pretty decent battery, untill u experience the same, for this problem i have factory reset the device and use minimum apps, the battery drains in idle mode if i have to go out for work, when i take phone with 100% and used only for calling less than 20 mins, battery drops to 15% in case of emergency, what should a normal person do with these, in case i extende my work for an hour, it gets switched off. Then what is the use of this phone. Don't blindly support anything.
harshitrao56
How to update mine .84 built to android 10 beta version because the battery backup is so shit in this .084 built
