Asus zenfone max pro m1 Android 9 build 84
usakiyem
Rising Star I
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
Battery drain so fast please give me solution
34 REPLIES 34
usakiyem
Rising Star I
mysahil0369
I haven't updated to 084 yet !
Should I ? Or not ?
It's your choice build 84 is useless in battery backup
usakiyem
Rising Star I
mandaldipayan15
https://zentalk.asus.com/en/discussion/33521/asus-zenfone-max-pro-m1-android-9-build-84
No I'm okay with it. Better you are adviced to install Avast Cleanup. And batch stop every possible app. It really works. And make a schedule to do it every night before sleep and restart the device also. Believe me, it works...
The boost memory option in the screenshot..
I don't like to install external app for battery drain issue
mysahil0369
usakiyem
https://zentalk.asus.com/en/discussion/comment/103857#Comment_103857
After seeing comments on this post , I will not install the update untill new update arrives .
sayyedsharuk55
A10 Stock Latest .429
Charging speed must be 1800-2000mA in Ampere app.. otherwise change your charger..
pubg played in Smooth+Extreme FPS...
sahaa6919
To be honest with you , the phone's battery backup is pretty decent .. You just have to not use your phone unnecessarily and if you think that battery is draining fast , do calibration .. It really works .. And , if u use ur device recklessly , the phone's battery will surely damage and will result in weak battery .. Take care of your device .. I'm adjoining a screenshot .. See , 2hrs time is left even on heavy usage in 25% battery ..
