Asus zenfone max pro m1 Android 9 build 84
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
Battery drain so fast please give me solution
Comments
It will go down even faster in the coming days , with me same thing happened , initially only 5-10% battery was losing in idol mode but now full charge goes down from 100 to 0 in less than 3 hours
So i think Worse is yet to come for you
Try doing a battery calibration by doing the steps below
Did it worked for you ? Because barring 2nd step I have tried this method
I have tried calibration, and it takes 4hrs (3hrs 50mins) to charge in switched off condition and my battery stands for about 3hr 17mins screen on time (without playing game) i used to watch youtube, insta and twitter. Let stop say to calibrate and give us a stable software. Its not a beta version (beta version having these problems are ok) but giving a security patch ruin battery life is ridiculous.
You guys really need to take care of your phones..... I am using the device for the last 2 years and the current software version is 084 ... Was facing this battery drain issue but charging it by switching it off helped.
No I'm okay with it. Better you are adviced to install Avast Cleanup. And batch stop every possible app. It really works. And make a schedule to do it every night before sleep and restart the device also. Believe me, it works...
The boost memory option in the screenshot..
Same problem but my battery got sowllen.
WTF battery backup in 084
Bakwas Asus wale 😠😠😠
WTF asus look at this , it sucks . Please fix it guys 😭😭
Battery backup in .084 is very good.
I'm also facing hugh battery drain in ideal time.
After change my battery everything is good.
Check picture below.
Why are you sad try custom rom
Internet sarfing me kam battery drain hoti hai
😡😠😠😠😠 Very first battery drain
Why my battery drainage is more for last 45 days
Some days ago, my Max Pro M1 needs 3 hours for full charge & next 3 hours its going to 0%.
I haven't updated to 084 yet !
Should I ? Or not ?
Build 84 is useless in battery backup
It's your choice build 84 is useless in battery backup
