Asus zenfone max pro m1 Android 9 build 84
usakiyem
Rising Star I
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
Battery drain so fast please give me solution
34 REPLIES 34
rick2014628
You guys really need to take care of your phones..... I am using the device for the last 2 years and the current software version is 084 ... Was facing this battery drain issue but charging it by switching it off helped.
usakiyem
  1. Model Name:
  2. Firmware Version:
  3. Rooted or not:
  4. Frequency of Occurrence:
mandaldipayan15
usakiyem
  1. Model Name:
  3. Rooted or not:
No I'm okay with it. Better you are adviced to install Avast Cleanup. And batch stop every possible app. It really works. And make a schedule to do it every night before sleep and restart the device also. Believe me, it works...
The boost memory option in the screenshot..
Mdskhan
harshitrao56
https://zentalk.asus.com/en/discussion/33521/asus-zenfone-max-pro-m1-android-9-build-84
It will go down even faster in the coming days , with me same thing happened , initially only 5-10% battery was losing in idol mode but now full charge goes down from 100 to 0 in less than 3 hours
So i think Worse is yet to come for you
Same problem but my battery got sowllen.
souravhudait41
souravhudait41
WTF battery backup in 084
