Asus zenfone max pro m1 Android 9 build 84
usakiyem
Rising Star I
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
Battery drain so fast please give me solution
34 REPLIES 34
Sathesh
nishantkd
https://zentalk.asus.com/en/discussion/comment/104191#Comment_104191
He isn't blindly supporting anything, he attached a screenshot too, the update isn't the problem, please check the condition of your battery, see if your device's back cover is bulging out, if so then the battery is swollen and you need to replace it, because however poor the update or signal strength maybe, no matter if the OS is properly optimised or not, the battery backup will never come down to 1 hr.
My device is almost 2 years old now, the battery capacity has come down to 4000mAh, didn't update to beta, my M1 Pro is on the latest pie firmware and I get pretty decent battery backup.
I havn't calibrated the battery for a long time, there are so many apps installed, nearly 70-80 applications, yet 7-8 hrs of SoT with nearly 25-30% charge remaining. When I got back home yesterday it was 50% with 5+ hrs of SoT.
Attaching the Screenshot for your refernce.
I can't accept your terms, till last version of my device, i don't have battery problem at all, as same as your device, the night i update the security patch, i kept my phone charger in range of 70% the next morning there is only 15% left over, is this a hardware problem? Seems not. Till date i have maintained better battery cycle, i don't over charge mostly i charge 30 to 95% im not a heavy user, and I don't play heavy games or online games. And i have contacted customer care, and they ask to calibrate the battery, i have tried that too, but there is no difference even after calibration. And now don't tell me that my usage is bad that cause battery drain, everything is because of software,. I choose this device because of its battery backup and software,. I have used a other device before, for about 4 years, i thought this would also be used for 4 years, and it stands only for two, DISAPPOINTED!!!.
Sathesh
nishantkd
https://zentalk.asus.com/en/discussion/comment/104834#Comment_104834
Never said and wil never mention bad usgae, there isn't anything as such. There are power user and even if you are a power user the battery should last a bit longer, only a few factors affect battery life the most and optimisation shouldn't be the first of them.
  1. Heat takes the heaviest of toll on battery life.
  2. Then comes network reception.
  3. Battery capacity is the last one, which is a hardware issue.
If you don't have any of these please check for wake locks and third party applications, I faced similar problem once but not to the same extent as yours, my SoT came down to 5 hrs and I went crazy, so I can understand how you must be feeling. In my case it was the media storage messing up with the battery.
I don't keep my data (media), i backup to drive every week.
sayyedsharuk55
usakiyem
https://zentalk.asus.com/en/discussion/comment/103881#Comment_103881
Build 429 ka battery backup tik hai
good hai.. but not best possible
sayyedsharuk55
dibyarupprk2011
Check that after getting calls if you receive the call notification lately by 3 to 4 Seconds
yes its lates by 3..4 sec but it dosent matter.. and you are not an agent in mission impossible..so that you need accurate timings...🤣🥰
dibyarupprk2011
Rising Star II
sayyedsharuk55
https://zentalk.asus.com/en/discussion/comment/104007#Comment_104007
Don't be a dumb ass!!
Oftentimes i never get alerted for missed calls, there are some situations where a automated call is being sent for verifying mobile number it doesn't work too..
Reporting of bugs is what this community made for..
