Asus Max Pro M1 Stable Android 10 Update Review with Screenshots...
roscheray101
Model Name: ZB601KL
Firmware Version: WW_Phone-17.2017.2004.424-2020.0414
Rooted or not: Not
Frequency of Occurrence:
I have just Downloaded and Installed the Android 10 update from the official site and these are some of the feedbacks.
The overall look has changed and it is very nice.
Miss the ambient display when there is a notification while the screen is locked which was there on earlier Android 9 version.
The flash light option on the taskbar is seemed kind of locked. Cannot be accessed. ( Issue solved by Restarting the phone)
The Dark mode works perfectly fine in all apps esp that of Google.
The new Boot animation has also changed and its good.
The Camera User Interface has also changed and it looks neat.
108 REPLIES 108
RAGNAROK
sameepmakwana9196
Asus Max Pro M1.
I have updated to android 10 two days back.
I'm facing the bluetooth problem with my wireless earphones. When I turned on and connect the wireless earphones, it connects and automatically bluetooth gets turned off. I tried even many times and after switch off and on phone the problem remains the same.
Help me to solve this problem.
I had this problem in pie. Upgraded to beta 1 android 10 and then downgraded back, the problem was gone.
Ps: this is not a useful solution, may not work sometimes
Try forgetting the device and pair again.
Sushena
Headphone audio quality is garbage so I would like to downgrade to android pie , pls someone help me!
basavaraj326
sk0061780
What about max pro m2?
I think the software is in both m1 and m2 are same , but they r not updating any thing about m2...☹️☹️
ganjack_333
Hell guys I face some issues after upgrading to built 424.
1. The speaker sound quality is very hazzy ... Sound is louder then previous Android 9 but feels like speaker is in overload. 👎
2. The audio quality of headphone / headphone jack is creepy, garbage . It's not lacking the base coz their is no base at all.
My senhizer 180 headphones are good in enhancing the base but by using these headphones I clearly notice for unpresnce of base. 👎
Actually in headphone sound is just like 40rs earphones ...😖
For making sure I change the headphone . But the problem has same... 😕
3. It seams like the brightness slider is not metered coz . After pulling the half way , brightness increases a very little change but after 70% on sliding bar than brightness level gets changing incrementally..🙄
Thus it's not like metered correctly ...
Rest of all gaming features are not optimize in this built. And also it's the main coz for the phone is not heating to much ..
Yes the phone not getting the burning heat problem.👍
So lastly any suggestions Boston! ,🤔
Axatp
Hello all,
Can I get the info about the update size of Android 10 downloaded by you.
And can I get the screen shot of battery section in settings. As I want to know that they have provided the adaptive battery option in Android 10.
