Asus Max Pro M1 Stable Android 10 Update Review with Screenshots...
roscheray101
Model Name: ZB601KL
Firmware Version: WW_Phone-17.2017.2004.424-2020.0414
Rooted or not: Not
Frequency of Occurrence:
I have just Downloaded and Installed the Android 10 update from the official site and these are some of the feedbacks.
The overall look has changed and it is very nice.
Miss the ambient display when there is a notification while the screen is locked which was there on earlier Android 9 version.
The flash light option on the taskbar is seemed kind of locked. Cannot be accessed. ( Issue solved by Restarting the phone)
The Dark mode works perfectly fine in all apps esp that of Google.
The new Boot animation has also changed and its good.
The Camera User Interface has also changed and it looks neat.
108 REPLIES 108
Shahed
roscheray101
  1. Model Name: ZB601KL
  2. Firmware Version: WW_Phone-17.2017.2004.424-2020.0414
  3. Rooted or not: Not
  4. Frequency of Occurrence:
Asus Max Pro M1 Android 10 Update Review
Flashlight issue happens commonly and can be fixed by restarting the device.
roscheray101
Thank u Shahed. It worked...... 😃
sk0061780
What about max pro m2?
nidhin3
Zen Master I
In the website its mentioned your data will be cleared. Did you loose the data ?
