High battery drain while not in use - about 10% overnight
baghe61
Recently I've noticed a high battery drain when I'm not using the phone, particularly overnight where it goes down around 10%. According to the stats, as much battery is consumed when my screen is off as when it's on. GSam shows no troublesome wakelocks or apps consuming more battery than they should, the battery consumption list is always topped by Android System and Kernel. Which is backed up by the information in the system battery information, which always shows "Other" as the biggest consumer. From the screenshots, do they look like they're consuming more than they should be? Any tips to stop them doing so? Are you guys experiencing the same? Thanks.
0 REPLIES 0
