10-25-2023 05:27 AM
now others drain 41 % of battery and screen time is gone from batteri settings. this phone just gets better and better!!
10-25-2023 05:54 AM
Hey @Bulletdracer,
Can you please share a log?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
10-25-2023 07:01 AM
i started log now.
But why did you turned off screen time from battery stats? it was very good to see me screen time eacg charge. now i dont know. other android phones have it
10-25-2023 07:23 AM
Hey @Bulletdracer,
To provide more accurate information about the battery usage of each application, the recent update (33.0220.0220.89) has included screen usage time information in the battery consumption of each application, and it is no longer calculated separately.
10-25-2023 08:04 AM - edited 10-26-2023 01:14 AM
thats was not really so smart.
How do we see screen time for every app? and do i have to sit with a calculator and go thru every app to see my screen time?
