Asus Max Pro M1 Stable Android 10 Update Review with Screenshots...
roscheray101
Model Name: ZB601KL
Firmware Version: WW_Phone-17.2017.2004.424-2020.0414
Rooted or not: Not
Frequency of Occurrence:
I have just Downloaded and Installed the Android 10 update from the official site and these are some of the feedbacks.
The overall look has changed and it is very nice.
Miss the ambient display when there is a notification while the screen is locked which was there on earlier Android 9 version.
The flash light option on the taskbar is seemed kind of locked. Cannot be accessed. ( Issue solved by Restarting the phone)
The Dark mode works perfectly fine in all apps esp that of Google.
The new Boot animation has also changed and its good.
The Camera User Interface has also changed and it looks neat.
108 REPLIES 108
What about the official update.. is it jus like how we installed developer version or it 2ill come as fota update??
Will the developer version erase all the apps too??
Should i install developer version or should i wait for the stable version?? Please reply..
mandysingh896
Please remove sound bug from Android 10 update . It's very annoying 😡. Poor sound quality and overall sound decreased to 50% of the stable pie. Please enable HD high graphics in pubg mobile.
ZT-35f7678e
Asus Zenfone max Pro m1
Model no। XOOTD
BULID। 063
mapparao1990
After android 10 update there is no wifi calling option for Airtel!
1234prabhat
Riyaz
I think we will never get native video calling support on Max Pro M1...!!!!😫😫😫
Not on max pro m1 any stock Android devices lacks it
Ask Google when they did..it will
