Asus Max Pro M1 Stable Android 10 Update Review with Screenshots...
roscheray101
Model Name: ZB601KL
Firmware Version: WW_Phone-17.2017.2004.424-2020.0414
Rooted or not: Not
Frequency of Occurrence:
I have just Downloaded and Installed the Android 10 update from the official site and these are some of the feedbacks.
The overall look has changed and it is very nice.
Miss the ambient display when there is a notification while the screen is locked which was there on earlier Android 9 version.
The flash light option on the taskbar is seemed kind of locked. Cannot be accessed. ( Issue solved by Restarting the phone)
The Dark mode works perfectly fine in all apps esp that of Google.
The new Boot animation has also changed and its good.
The Camera User Interface has also changed and it looks neat.
108 REPLIES 108
manojreddy_buda
Rising Star I
sudhangsudaredevils
I didn't get any fota updates from asus for 1 year. It's quite frustrating for me that I haven't got any pie updates also
Download .063 update manually from Asus website and put it in internal storage (don't put in any folder). Restart the device, a notification will pop-up saying "New Update detected", click on it. Wait for the system to finish the update. System restart's on it's own. You'll be updated to Android 9 pie with April security patch.
ajay_krsnan555
sudhangsudaredevils
See my security patch also
TRY CLEARING DATA OF THE FOTA SERVICE APP AND RESTARTING THE PHONE AND RETRY FOR CHECK UPDATE ..STILL IT DOES NOT WORK THEN GO FOR UPGRADING MANUALLY FROM ASUS OFFICIAL WEBSITE.
roscheray101
nidhin3
In the website its mentioned your data will be cleared. Did you loose the data ?
nidhin3
nop.. i did not loose any data. The update take some time .. be patient..
roscheray101
sudhangsudaredevils
please update it manually
nidhin3
Zen Master I
roscheray101
https://zentalk.asus.com/en/discussion/comment/77919#Comment_77919
Did you remove the password before installing ? Also you downloaded from Asus website, Right ?
Double checking coz a lot of important data is in my phone and I cant afford to loose them.
