Asus Max Pro M1 Stable Android 10 Update Review with Screenshots...
roscheray101
Model Name: ZB601KL
Firmware Version: WW_Phone-17.2017.2004.424-2020.0414
Rooted or not: Not
Frequency of Occurrence:
I have just Downloaded and Installed the Android 10 update from the official site and these are some of the feedbacks.
The overall look has changed and it is very nice.
Miss the ambient display when there is a notification while the screen is locked which was there on earlier Android 9 version.
The flash light option on the taskbar is seemed kind of locked. Cannot be accessed. ( Issue solved by Restarting the phone)
The Dark mode works perfectly fine in all apps esp that of Google.
The new Boot animation has also changed and its good.
The Camera User Interface has also changed and it looks neat.
108 REPLIES 108
josephnh950
I have manually downloaded the Android 10 update from the website and it works fine. In later days if there is any offical release of the update, can i get it in the system update?
vckanandvpp
Rising Star II
josephnh950
Yes . You will get.
VEL_ASSA
Rising Star II
I have a new bug.
vckanandvpp
Rising Star II
svela003@gmail.com
I have a new bug.
Yes , This bug is there with Max Pro M2 also. It will happen when we remove sim tray and insert a new sim without shutting down the device. It started happening after upgrading to Android 10.
souvikshaw4004
Vodafone VOLTE Not working
