Asus Max Pro M1 Stable Android 10 Update Review with Screenshots...
roscheray101
Model Name: ZB601KL
Firmware Version: WW_Phone-17.2017.2004.424-2020.0414
Rooted or not: Not
Frequency of Occurrence:
I have just Downloaded and Installed the Android 10 update from the official site and these are some of the feedbacks.
The overall look has changed and it is very nice.
Miss the ambient display when there is a notification while the screen is locked which was there on earlier Android 9 version.
The flash light option on the taskbar is seemed kind of locked. Cannot be accessed. ( Issue solved by Restarting the phone)
The Dark mode works perfectly fine in all apps esp that of Google.
The new Boot animation has also changed and its good.
The Camera User Interface has also changed and it looks neat.
108 REPLIES 108
Shahed
sk0061780
What about max pro m2?
Expect within a week or two.
Shahed
nidhin3
In the website its mentioned your data will be cleared. Did you loose the data ?
2nd point clearly says that.
nidhin3
Zen Master I
Shahed
https://zentalk.asus.com/en/discussion/comment/77919#Comment_77919
Ya I know. But some users are telling their data is safe and is not deleted. Thats why I asked.
When will the company release android 10 for max pro M1 as an OTA update rather than manually updating it ?
mukulbehare
Can u please tell me. Earphones bass is better than previous 10 beta update, i was facing some low bass in earphone but when i restart device problem solved,
