08-25-2022 09:40 AM
11-12-2022 02:50 AM
11-13-2022 06:56 AM
Mattias_ASUSi have generated the log, please tell me how can i share it directly with you...I got a reply from R&D and they can't seem to be able to recreate the issue, therefore I need help from users who are having the issue to create a log so we can find what might be causing the issue and answer some questions.
1.- Which kind of call is used when having this issue? Cellular? VoLTE?
2.- Does the problem occur when switching from the phone to the speaker? Does this happen only when changing the setting mid-call? or does this happen before the other user picks up?
3.- Did you do anything before the call? (ex: Game, listening to music, web browsing?)
4.- A log needs to be created replicating the issue, to which I will write the instructions down below.
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “Sound, call audio, and recording ” will work for this issue..
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
01-20-2023 10:50 PM
Dear Dev,
all company if there is issue or software bugs he try to fix in same time by update, now from august .... mean 5 month and still developer ask about log and send bug report i not believe 5 month there is problem and no have any person from developer can solve and asking about bug report, if there is any issue with Samsung or apple or any brand he will not asking about it direct he will found solution
11-14-2022 06:21 AM
efkoi have problem on rog 6 that people cant hear me wellI have the latest software WW-32.2030.2030.26
and the problem persists. For a while I thought it was caused by bluetooth, but even when I have both bluetooth and wifi turned off, the problem persists.
In addition, 8/10 people I talk to on the phone complain that they can't hear me well!
11-14-2022 06:24 AM
Kazionator@Mattias_ASUS same problem was on 165 firmware on rog 6@Mattias_ASUS yes, as I said before I am on WW-32.2030.2030.26 and I have this problem.
Also today I picked up a phone call, switched to the speaker and I could hear the other side on the speaker but he couldn't hear me.
