Zenfone 9 - Bluetooth connection issues
MatunS
Tried to connect to PC's and TV via Bluetooth to use as remote, but it disconnects and tries to connect again until it disconnects completely.
It works on multiple other phones without an issue.
22 REPLIES 22
Mansi_ASUS
Hey @MatunS, have you updated your phone to the latest firmware version?
MatunS
Hi, thank you for your reply.
Yes, I did, as soon as I initially set up the phone.
It tries to connect, but after 2-3 attemps it disconnects completely.
But that happens only with my PC's and TV, not my earbuds or car speaker.
Xiaoli
I also have issues using Bluetooth headphones (Bose 700) on it, it keeps dropping and reconnecting every couple of seconds.
I'm on 32.2030.2030.26
Mansi_ASUS
Hey @MatunS!
I heard back from the R&D team, in order to assist you further, they require the following information from your end-
Log details
Screenshots recording the detailed time when a problem occurs
Open “Calculator APP”
Enter “.19595+=”
Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
It takes several minutes for the log to generate. You can exit and do other stuff in the meantime. A silent notification will tell you once the process is done. Tap the notification and then the share button to upload the file to Google Drive and share the link with a moderator. Just make sure to change the permission first so that everyone with the link has permission to view it.
