Zenfone 9 battery drain
YuryM
After latest update a huge battery drain noticed = battery drain by others for 91% and screen on time just around 3 - 3.5 hours on full charge. Previously, it could be up to 6 hours
Phone: zenfone 9
Fw version: 33.0804.2060.204
5 REPLIES 5
Mansi_ASUS
Hey @YuryM,
I'd suggest you wait and observe the battery usage for 1-2 days. If the battery drain issue persists after 2 days, please provide the general log and battery usage screenshot for analysis.
@Mansi_ASUS it did not work, still got battery drain. It keeps the same, can you guide me how to proceed further?
Mansi_ASUS
Hey @YuryM,
Can you please share the log file?
You can capture the log by following the process given below-
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the logging tool via calculator and Tap "FINISH AND SHARE".
6. It takes several minutes for the log to generate. You can exit and do other stuff in the meantime. A silent notification will tell you once the process is done. Tap the notification and then the share button to upload the file to Google Drive and share the link with a moderator. Just make sure to change the permission first so that everyone with the link can view it.
Note: When you're no longer planning on logging your device, enter “.09595+=” in the calculator, and the logging tool will stop and delete all stored log files. Make sure to share via calculator. The files found in internal storage -> asus_log are not the correct files (only 1.2kb).
YuryM
@Mansi_ASUS i have sent sent you the link with the logs in the private message. Please let me know if you and engineers have got the access
