Zenfone 9 Android 14 Wifi Issue
vikhral10
Hello i was wondering if anyone is having the same problem as i did? My zenfone 9 have been updated to android 14 a few days ago and ever since the update my wifi on zenfone 9 would sometimes lose its connection and reconnect to the wifi again, this would happen every few minutes and so
This problem never occured to me before when im still using android 13 and to make myself clear my wifi router is working normally without any issue
Any help/suggestion would be much appreciated, thanks
Mansi_ASUS
Hey @vikhral10,
Can you please share a WiFi log?
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “Wi-Fi ”
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Girvan
Hello, im using zenfone 9 and currently having the same issue similar to you as well after updating to android 14....i've post similar threads on reddit for help/suggestion
