Odd Battery Behaviour
gurpz1
Model Name: ASUS_AI2022 (Zenfone 9)
Firmware Version: WW_33.0804.2060.189
Rooted: NO
Recently my phone's battery percentage level has started acting erratically - or rather - squarely .
Attached are screenshots from the phone's Battery Usage and battery seems to charge itself instantaneously before immediately jumping down to a more "normal level".
Has anyone else seen this behaviour?
Something for sure seems wrong to me.
13 REPLIES 13
leandro31187
other's Drain battery 32 %
My issue isn't so much a battery drain issue, rather that the battery appears to self charge and mis-report it's actual percentage.
Anonymous
Not applicable
this is one of the (many) well known issues with the latest .189 update. there is no fix available, as of right now. a future software update may fix this, but i wouldn't hold my breath.
asus does not care about their customers, they have communicated that very clearly.
Mansi_ASUS
Hey @gurpz1 and @leandro31187,
Can you please share the battery log?
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
