Marshall Major 4 unusable when using a 3.5mm cable
yaro330
  1. Zenfone 9
  2. WW_33.0804.2060.73
  3. Not rooted
  4. Always
  5. All apps
When I connect my Major 4 headphones to the phone using a 3.5mm cable (I have 3 different ones, the issue is reproduced on all three) the only thing I can hear is very loud white noise. Headphones themselves work fine when connected to other sources of sound, and my zf9 seems to work fine with other headphones.
I experienced the same issue on zf8 a long time ago.
13 REPLIES 13
yaro330
Same, I collected the logs, would be nice if I could share them privately.
while logged in, go to the admin's profile https://zentalk.asus.com/t5/user/viewprofilepage/user-id/293649
then there would be a "send a message" button
if it's not there, try to log in again
however, I'm not sure if it works since I didn't get any confirmation
Hey @yaro330, I've sent you a PM, you can share the log file there.
ZenBot
Community Manager
Community Manager
