12-22-2022 12:55 PM
01-02-2023 09:19 PM
Mansi_ASUSThanks for the tip. Is there a way to send the log file/contact the ASUS tech team/customer services directly with this?I've forwarded the issue to the R&DCan you please share the log file?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
You can share the log file via PM.
