Battery Drain Faster
berto35
Rising Star I
Model Name: Zenfone 9
Firmware Version: latest update available
Rooted or not: not
Frequency of Occurrence: often
Is anyone experiencing a faster battery drain after the latest update?
10 REPLIES 10
Mansi_ASUS
Hey @berto35 and @Sivy,
I've forwarded the issue to the R&DCan you please share the log file?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
You can share the log file via PM.
Madmax999
Sivy
I can confirm my phone also has substantial battery drain since updating to WW_33.0804.2060.73. non rooted phone. The battery under Android 12 used to last overnight and until approx mid day next day with light/moderate use (no gaming) whereas now it runs out by the evening. In addition, after reaching 3-5% it shuts down completely.
yeahh me too bro . what happend on this, should go back to a12?
Gabrieltg
Rising Star I
I have the latest Android 13 update and the battery life is perfect. With moderate use it lasts me more than 2 days.
juliusz_lichwa
Same issue, WW_33.0804.2060.73 and battery started to drain a lot. Before the update during the night phone used about 1-3% of battery (ultra saving).
Last night it was 11%...
Hello. Same issue in my phone.used to be great battery on Android 12 but after updating to 13 it is not so awesome as it used to be. Log here: https://drive.google.com/file/d/1-zthHwCuDN6Vt3eHV5LdmDL3X3HhCRQF/view?usp=drivesdk
