Zenfone 8 can not turn on wifi and hotspot
Ghaniiii
I have Zenfone 8 and can't turn on wifi and hotspot features after upgrading to android 13, any solution?
Falcon_ASUS
@Ghaniiii
According to what you described, please refer to the following FAQ to try to troubleshoot your Wi-Fi problem first.
https://www.asus.com/support/faq/1006657
If the issue persists, I have PM you for confirming your product warranty.
Please check the PM inbox at the top right corner of the screen and kindly provide the requested information.
