02-05-2023 06:40 AM
exactly 1 year of using asus zenfone 8 suddenly wifi doesn't work, hotspot doesn't work, and GPS doesn't work properly. all this started when I upgraded to android 13.
the warranty has ended suddenly an event like this happened. can I get an additional warranty?
previously I never experienced problems while using android 12
07-24-2023 09:32 PM
is it need to pay or free off charge?
07-24-2023 10:24 AM
I can't turn on my WiFi and hotspot. Try to reset WiFi settings but still not working. can you please help me how to fix this issue.
07-27-2023 06:35 AM
Well this is sad, it would be fine if this problem was caused by my own fault instead it wasn't, its sad to see how only some people have their problem solved yet here some of us left unresponded. If this is how asus handles their after sales with their zenfone i would never recommend others to try on the zenfone despite how good or perhaps decent the performance of their phones are.
08-04-2023 07:05 AM - edited 08-04-2023 07:15 AM
I had the same problem after the last update in mid-May of this year, although I got Android 13 back in February or March, and the wifi worked. It seems that Asus "scored" on Zenfone 8, he made such a conclusion after communicating with technical support in Ukraine, there they say that there are no mass appeals on this issue, they definitely do not read ZanTalk, since they asked for references to mass complaints, and the moderators in this community everyone is given a link to an instruction that does not solve the problem!
08-24-2023 06:36 PM
Last night, I did the android 13 update, and after, wifi is not working. The unfortunate thing is, my phone doesn't have any warranty anymore 😞
