wifi not work zenfone 8 after android 13 upgrade
beresyit
exactly 1 year of using asus zenfone 8 suddenly wifi doesn't work, hotspot doesn't work, and GPS doesn't work properly. all this started when I upgraded to android 13.
the warranty has ended suddenly an event like this happened. can I get an additional warranty?
previously I never experienced problems while using android 12
29 REPLIES 29
bobekos1
Rising Star I
Sprawdzałeś inne WiFi?
Jiaszzz_ASUS
Hello, @beresyit  thank you for reaching out.
Please refer to [Phone/Pad] What to do if my phone won't connect to a Wi-Fi network? for troubleshooting the Wi-Fi problem you might have first.
Meanwhile, I have PM you for confirming Wi-Fi issue details.
Could you please check the top right corner of the screen and kindly share the requested information in the PM inbox?
Dark1
I have same problem too. I don't know why wifi do not work after android 13 update
If it's still under warranty, I think Asus will be responsible for replacing the engine.
if the warranty period runs out like me, it's a hassle to have to pay expensive costs due to system problems like this
