wifi not work zenfone 8 after android 13 upgrade
beresyit
exactly 1 year of using asus zenfone 8 suddenly wifi doesn't work, hotspot doesn't work, and GPS doesn't work properly. all this started when I upgraded to android 13.
the warranty has ended suddenly an event like this happened. can I get an additional warranty?
previously I never experienced problems while using android 12
83 REPLIES 83
Any updates regarding your phone? Did you fix the problem? What did you do? You see the same thing happened to me, suddenly I could not use the wifi at all, it would disconnect and won't detect any network.
How much?
I have same probleme and my warranty has expired
Jiaszzz_ASUS
Hello, @Dark1 .
Could you please confirm if you have tried the above troubleshooting guide I mentioned?
Please check the top right corner of the screen and kindly share the details requested in the PM inbox.
Thank you!
I do all troubleshoot but the wifi still not working.
And if you downgrade to Android 12 back? Did you try?
