Proximity sensor problem during conversation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-23-2022 11:58 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2022 08:54 AM
Mattias_ASUSDidn't you mention a couple of months ago, that the next system update would provide a solution for the proximity sensor problem?Hello!
Today I got a reply from the team that asks for some details.
"1. First step – Check the P-Sensor function is properly
>> Start the calculator, enter .12345+= to start the SMMI tool, select Single Test > Proximity Test, and check whether the Sensor is normal
2. If the sensor detection is normal, provide a reproduction method (mainly video, because we want to know the angle of the other machine when answering),
>> Provide video + log, the video should be taken to the position of the opening of the Proximity sensor and the position relative to the ear (or hair or cheek, depending on the behavior of the user when it can be recreated)
3. If there is a problem with the sensor detection, it may need to be sent for repair "
As for how to create a log I will write it down here:
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-21-2022 01:35 AM
mattleNope, it was just some troubleshooting steps.https://zentalk.asus.com/en/discussion/comment/228852#Comment_228852
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-24-2022 11:19 AM
1. At the beginning of July 2022, I sent you the logs from my phone (you are asking for them again, so I will send you a link to them in a private message with a description in txt files, what I was doing when there was a bug)
2. After receiving the logs, you wrote on the forum that: "From the logs we got the devices triggered an auto-calibration to avoid stains, which might have caused an issue."
3. You know I don't have any extra cover on the screen and it's clean. Other users wrote the same.
4. So it seems you have identified a problem - the phone starts auto-calibration for no reason.
5. You cannot expect video recordings from us. How do you imagine it? Should I hold the phone with one hand and talk, and record myself with the other phone with the other hand? It would be possible if the bug was present all the time. Unfortunately the bug is there from time to time. I can't always have two phones and be ready to record.
6. All I can do is give you more logs from the phone. The logs should contain the position in which I am holding the phone, whether the sensor works and whether the screen lights up
7. I hold the phone to my ear normally. When the bug occurs, the way you hold the phone to your ear doesn't matter. If there is no error, I can move the phone and it does not appear. When a bug occurs, even pressing the phone completely to the ears and head does not eliminate it
8. I tested the sensor with the code you provided (.12345 + = to start the SMMI tool, select Single Test> Proximity Test) and it works in the range of about 2-4cm
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-24-2022 11:33 AM
Mattias_ASUS1. At the beginning of July 2022, I sent you the logs from my phone (you are asking for them again, so I will send you a link to them in a private message with a description in txt files, what I was doing when there was a bug)Hello!
2. Enter “.19595+=”
4. So it seems you have identified a problem - the phone starts auto-calibration for no reason. I'm not a developer, but I think autocalibration should be turned off and maybe this will fix the problem.
7. I hold the phone to my ear normally. When the bug occurs, the way you hold the phone to your ear doesn't matter. If there is no error, I can move the phone and it does not appear. When a bug occurs, even pressing the phone completely to the ears and head does not eliminate it. If you want, I can record a video while holding the phone, but the error will probably not occur during this recording.
8. I tested the sensor with the code you provided (.12345 + = to start the SMMI tool, select Single Test> Proximity Test) and it works in the range of about 2-4cm.
9. I also noticed that the problem may be related to the recording of calls - I have recording turned on. When in the "sound recorder" options I unchecked the "leave the screen on while recording" option, the bug started to appear less frequently.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-24-2022 04:08 PM
second issue (i know its off topic): because this effing phone doesn't officially support VoLTE on my home network (H3G Austria "3") i can't use regular phone calls in the USA! (although it's in the positive list of at&t and t-mobile).
this phone is produced for the garbage can!
