LDAC Earphones (Oppo Enco X2) not detected by Zenfone 8
sahil_ms
Recently I bought Oppo Enco X2, and it supports both LDAC and LHDC. Since LHDC is not yet supported by Zenfone 8, is it possible to do it via OTA? Since Zenfone 9 already supports it and there's no hardware limitation (My Xiaomi Pad 5 supports LHDC with a Snapdragon 860).
But the issue does not end here, HeyMelody app is not able to detect that Zenfone 8 supports LDAC, and hence it's not giving the option to switch to LDAC from SBC. This doesn't happen with Xiaomi Pad 5 and I can switch between LDAC and LHDC flawlessly.
The issue could also be only HeyMelody side, but from initial impressions, it seems like something is wrong on ZenUI side. I'll report the same thing on HeyMelody, but Asus Devs, please see to it too.
7 REPLIES 7
Ronzky321
sahil.ms
https://zentalk.asus.com/en/discussion/comment/221512#Comment_221512
Okay I figured this. Asus by default keeps SBC option enabled, so the HD audio: AAC in bluetooth settings was missing. Without the option turned on, I can't enable LDAC mode in HeyMelody. So switch to AAC in Dev Options fixed the issue.
SBC is mandatory so it's always ON. AAC is still a ver lossy codec esp for Android. Did you try checking in Bluetooth Settings while the TWS is connected? Beside the name of the TWS there's a gear icon to change the Bluetooth device's settings (name and a toggle for aptX/LDAC). If it's OFF, surely the app will not recognise LDAC/aptX support.
sahil_ms
Ronzky321
https://zentalk.asus.com/en/discussion/comment/221881#Comment_221881
Strangely, the AAC mode was not visible until I switched to AAC in the developer settings, which is strange as it should always be there. But now after enabling it, I can toggle AAC in device bluetooth settings .
ASUS_Bot
Rising Star II
